CWall_333_32537's avatar
CWall_333_32537
Jun 06, 2018
Does check-cert have a limit of how many certs ?
I have certificates expiring in 30 days on the LTM, but tmsh run sys crypto check-cert returns none.
If I run tmsh run sys crypto check-cert verbose enabled
I only see 276 out of over 450 certificates in the list
  • JG's avatar
    JG
    Are these certificates all in the same partition?
  • The checkcert utility examines all the certificates in the /config/ssl/ssl.crt directory... you confirm that all your certificates are well located in this directory?
