Do we have a way to bypass wideip and go to zonerunner instead?
Hi
I want to list all of my website and see what ip they have. (ie www.abc.com IP 1.1.1.1 2.2.2.2 | www.cde.com IP 3.3.3.3 4.4.4.4 )
we can read file configuration but it's tough work due to many hundred of website. so I want to try using dig script to get all ip from website instead.
Problem is If i don't bypass wideip. F5 will answer only one IP which it's expected behavior.
So I want my machine to bypass wideip and go to zonerunner directly. So I can use dig and get all ip of those website. (just my machine cause other people have to work properly)
Is there a way to do this ? Maybe iRule ?
Thank you
- kridsana
Cirrocumulus
If not iRule. can we create a new listener which not using wideip processing?
- jaikumar_f5
Noctilucent
You can goto /var/named/config/namedb location and check your db files. All zone entries will be there.
- Halil_İbrahim
You can disable GSLB in DNS profile. So, your listener will bypass Wideip and go on with cache and DnsExpress.
