SAP's avatar
SAP
Mar 26, 2020
DNS Resolver for System Configuration not working
Hi ,
Is there a way to check which name server LTM would consider using which it would create the ephemeral node ? I have 4 configured 2 are reachable and 2 are unreachable. Still LTM is not creating the ephemeral node. Any suggestions would be helpful.
  • Suggestions: If 2 ​ephemeral node is resolving out of 4 mean dns is resolving ip address.
    Did ​you run the dig command to check right name server?
    Try below command.​ Example:
    dig example.com +short +identify
    dig foo.example.com +all
    ​Let's us know the issue.
    Thanks​
    • SAP's avatar
      SAP
      Hi Samir,
      I meant i have 4 name servers configured. But ephimeral node still doesn't populate.
      Out of 4 two name servers are reachable from device and 2 are not reachable. Ideally it should populate the ephimeral node but issue here is it doesn't.
