vyrs_278584's avatar
vyrs_278584
Jul 12, 2016
Display specific headers
I'm passing PKI certificate information inside headers and have a VIP that displays a user's headers for troubleshooting access problems. I updated my iRule to insert the entire certificate into a header but I don't want this information displayed along with the headers I usually pass. How can I display all of my headers except the one titled base64?
How I insert the whole certifiate into the headers:
HTTP::header replace BASE64 [X509::whole [SSL::cert 0]]
How I normally display headers on my troubleshooting site:
foreach header [HTTP::header names] {
  set HEADER_RESPONSE "$HEADER_RESPONSE > $header = [HTTP::header $header]
My attempt to fix exclude the whole certificate header:
            if { ! [matchclass [string tolower [HTTP::header names]] starts_with "base" ]} {
  • Hello, what are you using matchclass in you condition ? remove that and that should do the trick.
  • you don't need matchclass as it is for datagroup matching.
    This is a bit of a basic programming errror. All you need to do is just skip the loop iteration you don't want using continue operator:
            if {$header eq "BASE64"} {continue}
    Hope this helps,
    Sam
