Derek_21893's avatar
Derek_21893
Aug 06, 2009
Discovery of failover peer using iControl
I'd like to be able to discover a failover peer for an active-active or active-standby pair of LTMs using iControl. From what I can tell there is no good way to do this currently.
I can use System.Failover.get_peer_address to get the address of the peer, but if this address is not routable (I'm not sure you can even make it routable) then how else can you discover a usable IP address for the peer?
In my instance the primary LTM is using 192.168.255.1 and the peer is using 192.168.255.2. All I can get is the peer address. I can't even get the "self" address, so even if these IP addresses were unique across an enterprise, there would be no way to correlate the two LTMs together into a redundant pair.
The only way I can think of to figure out if two LTMs are in a failover pair is to compare the VIPs and maybe self-ips to see if the IP addresses match, which is a cludge at best and wouldn't cover all scenarios such as multiple pairs of LTMs which their VIPs are participating in anycast and thus all have the same IP addresses across multiple pairs of LTMs.
Any ideas?
Thanks,
-Derek
