AndyOrd_5655's avatar
AndyOrd_5655
17 years ago
discard for dummies
Excuse me in advance if I'm asking a very "irule novice" question.
If I setup an irule and the end statement is discard what will this actually do with the request ? Ta.
  • hoolio's avatar
    hoolio
    Discard will cause LTM to drop the request packets from the client. Nothing else will happen on LTM until the idle timeout occurs. If the client hasn't already closed the connection, LTM will send a RST to the client.
    If you have questions on iRule commands, you can check the iRule wiki (Click here). A simple short cut is to just add the command or event to the end of this URL:
    http://devcentral.f5.com/wiki/default.aspx/iRules/
    So for discard it would be:
    http://devcentral.f5.com/wiki/default.aspx/iRules/discard
    If the command has colons, replace them with underscores. So HTTP::redirect would be:
    http://devcentral.f5.com/wiki/default.aspx/iRules/http__redirect
    Aaron
