J_48024
Dec 08, 2014disabling SSL3.0 negotiations on management port
How to disable SSL3.0 negotiations on management port?
Thanks,
- Brad_Parker
Cirrus
TMSH modify /sys httpd ssl-ciphersuite 'ALL:!SSLv3', or any cipher string you want to use that will not include SSLv3.
- J_48024
Thanks Brad: spot on. I also found the below link which helped me further.
https://devcentral.f5.com/articles/cve-2014-3566-removing-sslv3-from-big-ip
