Vivek_Padale_16
Jul 30, 2014Disabling SQL injection and XML Tagging for a specific URL
Hello Everyone,
I want to disable SQL injection and XML Tagging attack for this url:-
"http://mybase.com/users/profile".
So is there any iRule for disabling SQL injection and XML tagging for the above URL.
Thanks.
- mimlo_61970
Cumulonimbus
I would recommend F5's ASM module to handle this, assuming the application/website cannot be fixed to address the problem. Escaping input at the app level works a lot better than pattern matching at the network level. - Vivek_Padale_16
Thanks Mimlo for your input..... - Arnaud_Lemaire
Employee
Vivek, could you stick to your initial post please ? i provided you with an answer here for SQL injection unnblock: https://devcentral.f5.com/questions/irule-for-asmanswer100884
next step for you is to identify the attack type form XML tagging and add it with a or in the matching condition.
thanks.
