m91280_56563's avatar
m91280_56563
Nov 12, 2009
Disabling Node by Icontrol do not visible on web interface ?
I try to use the script nodeserver.pl (http://devcentral.f5.com/wiki/default.aspx/iControl/DisablingNodeServers.html) to disable/enable node server but the change is not visible on web interface ?
does somebody know this issue ?
I use BIG-IP LTM verion "10.0.1 Build 283.0 Final" and "9.4.7 Build 320.1".
  • This script is most probably from version 4.0 "Node Server" is something that existed in BIG-IP v.4
    in v.9-v.10 you have nodes and pool members.
    Have a look at:
    http://devcentral.f5.com/Wiki/default.aspx/iControl/ToggleNodeAddress.html
    http://devcentral.f5.com/Wiki/default.aspx/iControl/TogglePoolMember.html
    http://devcentral.f5.com/Wiki/default.aspx/iControl/PoolToggle.html
    Sam
