Adrien_Legros_1's avatar
Adrien_Legros_1
Jun 05, 2009
Disabling ASM for clients coming from an internal network
We have a virtual server for a web application and we'd like to test the ASM only for the internal people. So I created 2 pools, one for the external users and one for the internal users. The ASM should only verify incoming requests from the internal network.
How can I (via an irule?) disable the ASM when i see external request and enabling it when i receive internal requests?
Thanks.
  • Benjamin_9036's avatar
    Benjamin_9036
    Historic F5 Account
    Hey Adrien,
    This depends, at least partially, on what version you are using. The methods to disable the ASM within iRules has changed a few times. If the internal and external clients will be from different networks, it should be fairly simple to define an iRule to do this. This has come up a time or two before, in fact. Have a look at the solutions we talked about in this post:
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=47&postid=34111&view=topic
    The best solution is probably a hybrid of these rules. This, to filter based on client IP address:
    http://devcentral.f5.com/wiki/default.aspx/iRules/AccessControlBasedOnIP.html
    Then this to bypass ASM:
    https://support.f5.com/kb/en-us/solutions/public/7000/600/sol7616.html
    Cheers!
    // Ben
  • hoolio's avatar
    hoolio
    There's been yet another change in how to disable ASM in v10.0.1 (covered in SOL10128, but not in SOL7616). Apparently there isn't a supported method for doing this at all in 10.0.0. See SOL10128 for details.
    SOL10128: The PLUGIN iRule commands do not function in BIG-IP version 10.0.0
    https://support.f5.com/kb/en-us/solutions/public/10000/100/sol10128.html (Click here)
    It would be ideal if the PLUGIN::, ASM:: and WAM:: commands could be documented in the Wiki at some point (nudge, nudge).
    Aaron
