disable http TRACE method on Load Balancer
Hi Folks, I need to know that is it possible to disable http trace method on https VS running on BIG-IP LTM 11.3, if yes how to achieve this ?. We do not have ASM module.
Please help Thanks Tabish Mirza
- Eric_St__John
Employee
It can be done with an iRule. Here is a post from a few years ago with an example.
- nathe
Cirrocumulus
There's a good article by security guru Josh Michaels which addresses this requirement (and more).
See Security iRules
Hope this helps,
N
- Tabish_Mirza_12
Hi Eric & Nathan,
I am very much confused. Could you please guys tell me exactly how to write this irule as I damn poor about it. I really appreciate your help. We have https VS & our goal is to disable https trace method. I have seen the above link but not getting exactly how to write it.
Awaiting for your positive & prompt response.
Thanks Tabish Mirza
