Miguel_Alfaro_6
17 years agodisable HTTP parsing for not HTTP traffic
Hi
I want to apply http acceleration profile to a VS order to ebable WA for an application (oracle Ebussines 11i), the problem is that part of the application is not RFC compliant with HTTP and it cause that the Http Profile hangs the connection, because the HTTP profile applies a fairly strict HTTP parser to the VIP.
I want to create an iRule that looks at the start of the connection and disables the HTTP parsing if it sees some part of the applicaiton traffic is not HTTP.
Do I should use TCP::collect or HTTP::collect
I will appreciate any example.
TNKS
- hoolio
To inspect the HTTP before the HTTP parser does you'd need to use TCP::collect. You could then call HTTP::disable from CLIENT_DATA if you don't want to use the HTTP profile for that connection.
TCP::collect (Click here)
CLIENT_DATA (Click here)
HTTP::disable (Click here)
Aaron - Miguel_Alfaro_6
Hi Aaron
Here is exactly the path where the application is getting stuck
/OA_JAVA/oracle/apps/fnd/formsClient/OracleApplications.dat
I will try disabling the http profile if the irule find a portion of that uri path
if { [HTTP::uri] contains "OA_JAVA" } {
HTTP::disable
} - hoolio
Hi Miguel,
If the issue only occurs after parsing the HTTP headers, then yes, using HTTP::disable in HTTP_REQUEST should work.
Aaron
