Disable and re-enable a pool member using powershell
Good afternoon; As a bit of background I'm a powershell newbie with limited knowledge of the f5-ltm module. Here is my question, is there a way to user Powershell to disable and re-enable pool members within a specified pool and partition?
Thank you for any and all input.
Norm
- JG
Cumulonimbus
I hope this one will of help to you: https://devcentral.f5.com/questions/using-the-ltm-rest-api-via-powershell .
There are a lot of samples listed in the iControl wiki's Powershell page.
Specifically this article on Graceful Server Shutdown should point you in the right direction.
