Jonathan_Scholi's avatar
Jonathan_Scholi
14 years ago
Direct traffic based on POST result
I got a request to send traffic to one of two servers based on the the contents of a POST request. Specifically, if a certain reference parameter in the POST is even, one server takes the traffic, and if the reference parameter is odd, the other server takes the traffic. The Tcl modulo operation works as expected, as determined by looking at the logs, but the correct server is not selected. The rule is like this:
HTTP::version "1.0"
if {[active_members mysite.com] > 1}{
  if { [HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"]  0 } {
     HTTP::collect $content_length
when HTTP_REQUEST_DATA {
  set payload [HTTP::payload]
  set reference ""
  regexp {reference=([0-9]+)} $payload blank reference
  if {$reference % 2 == 0}
  pool mysite.com member 10.11.12.13 443
  log local0. "Reference ends with even"
  log local0. "[LB::server]"
  elseif {$reference % 2 == 1}
  pool mysite.com member 10.11.12.14 443
  log local0. "Reference ends with odd"
  HTTP::release
The logs show the expected "Reference ends with even/odd", but the server persists in using the wrong server half the time. Persistence is not enabled. Is there a better approach I could be taking here?
  • Something in the forums seems to be trimming the "when HTTP_REQUEST {}" block, but that part behaves as expected.
  • Sorry, I just realized this is posted in the wrong forum. I meant iRules, not iControl. In any case, the solution I found for the above issue was to use independent pools rather than individual pool members.
