Differences between 11.6 and 12.1
Hi all, why is this working in 11.6 but not in 12.1?
In version 11.6 the policy-item was successfully created:
tmsh create apm policy policy-item ap_test_01 caption ap_test_01 item-type terminal-out
Verify that the item was created (do the command again):
01020066:3: The requested Access Policy Item (/Common/ap_test_01) already exists in partition Common.
In version 12.1 the same command generate an error:
01071933:3: The access policy item (/Common/ap_test_01) is not referenced by any existing access policy
Both configurations are on a new clean install iso. What is missing on 12.1?
- James_Thomson
Employee
It just looks like 12.1 doesn't allow you to create the object while it is not attached to a policy, but I can't even figure out a way to create it and attach it to a policy simultaneously. Are you able to create a support case and ask them what they expect? The TMSH guide isn't helpful as it just says "Use the GUI"
- Erik
I created a support ticket and got an excellent answer :-) This was a new way to do it. But, then I need to translate this for use with the curl-command.
tmsh create cli transaction
create apm policy agent ending-allow /Common/eple_end_allow_ag { }
create apm policy agent ending-deny /Common/eple_end_deny_ag { }
create apm policy agent ending-deny /Common/eple_end_deny2_ag { }
create apm policy policy-item /Common/eple_end_allow { agents add { /Common/eple_end_allow_ag { type ending-allow } } caption Allow color 1 item-type ending }
create apm policy policy-item /Common/eple_end_deny { agents add { /Common/eple_end_deny_ag { type ending-deny } } caption Deny color 2 item-type ending }
create apm policy policy-item /Common/eple_end_deny2 { agents add { /Common/eple_end_deny2_ag { type ending-deny } } caption Deny2 color 4 item-type ending }
create apm policy policy-item /Common/eple_ent { caption Start color 1 rules { { caption fallback next-item /Common/eple_end_deny } } }
create apm policy access-policy /Common/eple { default-ending /Common/eple_end_deny items add { eple_end_allow { } eple_end_deny { } eple_end_deny2 { } eple_ent { } } start-item eple_ent }
create apm profile access /Common/eple { accept-languages add { en } access-policy /Common/eple}
submit cli transaction
