Robert_Dehn_110
Jan 04, 2007Difference between persist and session command
Greetings all.
I have been tasked with creating an irule to do JSESSIONID persistence and have found a number of posts on this forum very helpful in the creation process.
The appears to be a couple different ways to create the persistence table entries required and I am wondering if either of the two ways are more effiecient or less taxing on the load balancer to use.
It would appear that I "SHOULD" be able to use either of the two commands below to achieve my goals.
Option 1) persist add uie $jsess 1800
Option 2) session add uie $jsess [IP::server_addr] 1800
Is there any real meaningful difference in this case between using the "persist add" command and the "session add" command?
