Nunes_344152
May 30, 2018Device group Viprion and VE.
Hello everyone
I am starting with the use of BIG-IP, and I would like to ask a question, it is possible to create a cluster with a Viprion + VE, as is the association of vlans to the physical interfaces since there can be differences between them, for example configuration of port-channel on the hardware side.
Thank you.
- youssef1
Cumulonimbus
you will find all information in the following link:
https://support.f5.com/csp/article/K8665
Just for information, you want to set a cluster with a VE and Guest hosted in a virprion or
VS and Viprion (not a guest)?
regards
