wayney_128269's avatar
wayney_128269
May 14, 2008
detect out of sync using checksum?
Is there way to look at say for example a checksum of some sort that I compare on the Active and Standby device to find out if they are out of sync instead of looking at timestamps?
thanks
wayne
  • Everything that there is is in the bigdb database under the Configsync key.
    $ b db | grep Configsync
    I think you are going to be stuck with using times, although there are multiple times you can go by (local config time, local synced time, peer config time).
    -Joe
