stephen1's avatar
stephen1
Mar 16, 2014
Detect mobile device use iRule
dear All,
I seem to be spinning my wheels here and I am not sure why. I want to do the following:
1.Detect if a user is coming from a mobile device
Redirect the user to a mobile optimized site, but: 1.if user used mobile device enter www.mydomain.com will be redirect m.mydomain.com , my iRule example:
if { [HTTP::header User-Agent] matches_regex "(Android|bb\d+|meego).+mobile|avantgo|bada\/|blackberry|blazer|compal|elaine|fennec|hiptop|iemobile|Android|iP(hone|od|ad)|iris|kindle|lge |maemo|midp|mmp|mobile.+firefox|netfront|opera m(ob|in)i|palm( os)?|phone|p(ixi|re)\/|plucker|pocket|psp|series(4|6)0|symbian|treo|up.(browser|link)|vodafone|wap|windows (ce|phone)|xda|xiino"} { HTTP::redirect "http://m.mydomain.com" } }
2.if mobile device user click change site icon , the icon url is http://www.mydomain.com?fr=mb , mboile device user will be redirect http://wwww.mndomain.com web site, how can determine in irule
please help me
  • Hi you need to use {} to enclose your regex instead of "". Also for the iRule try this;-
    if { [HTTP::header User-Agent] matches_regex {(Android|bb\d+|meego).+mobile|avantgo|bada\/|blackberry|blazer|compal|elaine|fennec|hiptop|iemobile|Android|iP(hone|od|ad)|iris|kindle|lge |maemo|midp|mmp|mobile.+firefox|netfront|opera m(ob|in)i|palm( os)?|phone|p(ixi|re)\/|plucker|pocket|psp|series(4|6)0|symbian|treo|up.(browser|link)|vodafone|wap|windows (ce|phone)|xda|xiino}} {
         It's a mobile device
        if {[HTTP::uri] eq "/?fr=mb"} {
            HTTP::redirect "http://www.mydomain.com/"
            HTTP::redirect "http://m.mydomain.com/"
  • Hi you just need to add some loggin to work out why it's not matching as you expect. I've just show a fragment below to show where to log;-
        log local0. "Redirecting [HTTP::uri] to http://www.settour.com.tw/"
        HTTP::redirect "http://www.settour.com.tw/"
        log local0. "Redirecting [HTTP::uri] to http://m.settour.com.tw/"
        HTTP::redirect "http://m.settour.com.tw/"
    Then you have to check the logs in /var/log/ltm - you should quickly figure out where you are going wrong.
  • Hello Stephen,
    You can try below iRule, I have same kind of requirement and the below iRule is working fine.
    when HTTP_REQUEST { set uri [string tolower [HTTP::uri] ]
    set mobile_site "http://m.mydomain.com"
    set full_site "http://www.mydomain.com"
            switch -glob [string tolower [HTTP::header User-Agent]] {
                "*iphone*" -
                "*android*" -
                "*windows phone*" -
                "*windows ce*" -
                "*bada*" -
                "*bb10*" -
                "*blackberry*" -
                "*symbinos*" -
                "*symbain os*" -
                "*symbian*" -
                "*java*" -
                "*winowsphone*" -
                "*windowsce*" {
                    return
    Regards, Ashish.
  • InnO's avatar
    InnO
    Hi Ashish,
    there may be a typo in "winowsphone", no ?
    Thanks, Pascal.
