Nick_T_68319's avatar
Nick_T_68319
Apr 29, 2009
Deploying nodes using EM changesets/templates
So I am trying to learn the EM. I want to deploy 50 nodes to a LTM. So I created a template like so
@define @node_ip
@define @node_name
F5[Local Traffic / Node]
F5[$target_partition$]
node @node_ip {
session disable
screen @node_name
The template seems to be fine, so then i go to tasks>stage a changeset
I select my template, then the LTM.
So this is cool, it allows me to enter the value's for that one node. Is there anyway to expand on this, and make it so i can deploy a bunch?
