James_Price_485
Mar 11, 2011Deploying f5 with sharepoint 2010 domain controller questions
The Deploying F5 with Sharepoint 2010 document has a figure 1.1. which shows the domain controllers on the internal network of the f5. Does anyone know if these DC's need to be on a separate domain? If so can the domains be shared through the f5? Is there any corresponding Microsoft documentation on this kind of configuration?
- Helen_Johnson_1Historic F5 AccountHi James,
There's a note in Technet that's along the lines of your question: http://technet.microsoft.com/en-us/library/cc262350.aspx
I suspect the answer also hinges on whether these domains will trust each other, and/or if they're part of the same forest as well.
Cheers,
Helen
