Tut_307973's avatar
Tut_307973
Jan 27, 2017
Deploy BIG-IP Edge Client (iOS) with configuration string
Greetings all, I'm very new to F5 (only responsible for deploying Edge Client with MDM) and need some basic assistance.
Are there any more examples available for Configuration XML strings used to deploy the Edge Client via MDM and VPP to iOS devices with connection settings already established? Specifically we are utilizing JAMF as our MDM. Apps can be given configuration settings in their deployment. I was attempting to use the below string but I'm getting an error - 'Incorrect Format'. Help is appreciated. Thanks!
We are using user name and password for authentication, and it is an SSL appliance.
    IPv4
    UserDefinedName
    The Name of our connection
    VPN
        AuthName
        $USERNAME
        RemoteAddress
        our F5 Address
        OnDemandMatchAppEnabled
    VPNSubType
    [com.f5.F5-Edge-Client.vpnplugin](//com.f5.F5-Edge-Client.vpnplugin)
    VPNType
    VPN
