plavender_72604
Dec 02, 2008Denying x-forwarded-for and true-client-ip optimisation
Hello,
I have found the following iRule that has been posted:
if { [HTTP::header exists "X-Forwarded-For"] } {
set xff [HTTP::header "X-Forwarded-For"]
xff may be in format of addr1,addr2,addr3
set addrs [split $xff ","]
foreach addr $addrs {
if { [matchclass $::banned_addr_list equals $addr] } {
reject
I would like to be able to also search in the true-client-ip header as well and have both parts reference a different class list. So, I am guessing that both parts of the iRule would like this:
reject
if { [HTTP::header exists "True-Client-IP"] } {
set xff [HTTP::header "True-Client-IP"]
reject
But I am not going very good at scripting and don't know how to combine them.
Any help would be great!
- Colin_Walker_12Historic F5 AccountCombining the two iRules is as easy as just copying the section that isn't duplicate code from one, and pasting it into the other.
What you'd end up with is something like this:when HTTP_REQUEST { if { [HTTP::header exists "X-Forwarded-For"] } { set xff [HTTP::header "X-Forwarded-For"] xff may be in format of addr1,addr2,addr3 set addrs [split $xff ","] foreach addr $addrs { if { [matchclass $::banned_addr_list equals $addr] } { reject } } } if { [HTTP::header exists "True-Client-IP"] } { set xff [HTTP::header "True-Client-IP"] xff may be in format of addr1,addr2,addr3 set addrs [split $xff ","] foreach addr $addrs { if { [matchclass $::banned_addr_list equals $addr] } { reject } } } }
HTH,
Colin
