Ricardo_Raza_14's avatar
Ricardo_Raza_14
Jan 02, 2019
delay in web page
Hi I configure a web page through F5: node: 192.168.x.110 vs: 192.168.y.110
But I have 2 problems:
  1. I have a delay near 2 minutes, I only configure vs standard, profile tcp_lan_optimized and not use snat because the gw of server is f5
  2. The other problem is that the web page only open the letters, but the form like css, graphics and other things don't show.
Please your help about this problem
  • I am not sure if you just worded it wrong. Did you create a node for your webpage or did you create a pool member and add the pool to the virtual server? Is the pool member listening on port 80 or 443? Is the virtual server listening on 80 or 443? Are you doing SSL offload? Make sure your web application is listening on the port that you are entering into the F5.
