Alan_Stevens_93
Dec 04, 2008Default Document not displaying in IIS
Hi all,
new to the big IP admin side of things so bear with me.
We have 2 IIS6 nodes serving up static content behind a big IP virtual. There are no iRules or profiles in place for this load balanced setup. The pool is using gateway_icmp for a health monitor. The send string is GET / no return strung.
here is what my problem is:
a user can go to http://www.sitename.com and is served the default document. A user can go to http://www.sitename.com/support/ and is served the default document. However, if a user tries to go to http://www.sitename/support - without the trailing /, the session times out on 404. If I go local to the server, I can have the page delivered with either method.
Is there a configuration change that can be made to allow the Big IP to pass the request correctly? Or perhaps an iRule?
Thanks for the help.
- James_Quinby_46Historic F5 AccountThis sounds like the ol' trailing slash problem, which has been a bane of webmasters for years.
Take a look at these threads:
https://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&postid=12294&view=topic
https://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&postid=4112&view=topic
...which show some iRules that can help. - Alan_Stevens_93
Thanks for that train of thought. This rule:
set uri [HTTP::uri] if { ! ( $uri ends_with "/" ) } { append uri "/" HTTP::uri $uri }}
seems a bit bruteish though, as it will append the / to ANY uri stream. I have some other iRules in place on this virtual that would probalby not like this too much. Specifically, some redirect rules that are sorting by trailing /blah. If I am understanding this correctly, that would then make -/blah- change to -/blah/- which would break the redirect? - James_Quinby_46Historic F5 AccountI read that iRule to say "for all URIs that do not already end in '/', append a '/'". This would include any final files as part of the URI string, so yeah, it's a bit heavy-handed.
If that casts too wide a net, you might create a data group of URIs that are to be fixed with a trailing slash, and then reference that in the iRule.
(Though that's not to say that there may be a better, easier way as well...there almost always is). - hoolio
I'd try investigating what exactly is failing before taking the sledgehammer approach of trying to modify the requested path in an iRule. I'm not sure why you'd get a failure if all you're doing currently is accepting an HTTP request and load balancing to an HTTP server.
You can use a browser plugin like HttpFox or LiveHttpHeaders for FF or Fiddler for IE to see what the exact request and response headers/bodies.
Aaron - Alan_Stevens_93
Thanks for the help guys. A question I haven't been able to find an answer to is this: is there a generic http rule that you should put in place on any virtual to handle traffic? somethign like this?
when HTTP_REQUEST{
if [HTTP:uri] equals ""} {
HTTP::uri}
Or is this handled automatically? - hoolio
A URI should never be null--it's not valid. If a user enters www.example.com in a browser, the browser must append a trailing slash and the protocol: http://www.example.com/. The URI for this request would then be /. So no rule is necessary to ensure the client doesn't make a request with a null URI.
Aaron
