blake_traister3's avatar
blake_traister3
Jul 16, 2015
Datagroup addition problems
In my F5 data groups, in the gui, it shows NO addresses, but if you look it up in the CLI, it does:
tmsh list ltm data-group internal admin_datagroup_SCAN 01020036:3: The requested class (internal) was not found. ltm data-group admin_datagroup_SCAN { records { 10.1.40.31/32 { } ---SNIP 185 Records--------- 10.161.10.18/32 { } } type ip
Is there a way I could just reload all the records into a text file and merge it back into the config using TMSH?
  • Here's what I would do (in order):
    1. Log out and log back in. Does that fix it?
    2. Try to export the data group as a file:
      tmsh list ltm data-group internal [data group name] > dgfile
      Are all of the IPs in the exported file?
    3. If the exported file has all of the addresses, delete the data group and re-merge:
      tmsh save sys config merge file dgfile
      You should see the data group re-added in the GUI config. Does it work?
    4. If still nothing, reboot the box.
    5. If still nothing, open a support case.
