ndaems_145583's avatar
ndaems_145583
May 20, 2014
Customize BIG-IP Edge Client
Hi All,
In order to avoid any wrong manipulation from End User I would like to know if it's possible to block some feature in the client
Is it possible to disable the following buttons (see picture)
I already looked at the customization guide but don't find the appropriate setting
Thanks for your help
Regards
Nicolas
