kckirwan_49724
Jul 19, 2007Custom Reporting with iRules Sync issue
All,
I am still somewhat of a newbie to the iRules world. I found the Custom Reporting with iRules article in the Docs and Tips section.
I followed the instructions as outlined and I will say that the functionality works great. I found one "huh????" occurence when doing either a manual config sync to my standby BIGIP or attempting to do a b load.
Anyway.... here's what I see when I issue a b load command.
Reading configuration from /config/bigip_base.conf.
Reading configuration from /usr/bin/monitors/builtins/base_monitors.conf.
Reading configuration from /config/profile_base.conf.
Reading configuration from /config/daemon.conf.
Reading configuration from /config/bigip.conf.
BIGpipe rule query error:
012e0010:3: Unrecognized value for the profile stats field1 attribute:
20x field2 30x field3 40x
In my configsync_peer.log, the following "warning appears".
Reloading configuration... It may take a few minutes...
Here is what my stats profile (as described by the article) looks like:
profile stats user_experience {
defaults from stats
field1 20x
field2 30x
field3 40x
field4 50x
field5 num_requests
field6 total_time
Am I missing something???
Thanks in advance for any assistance anyone may be able to offer......
- Al_Carandang_11
I had similar issues trying whenever I tried to do a 'b merge' with this profile. However when I typed the fields into the GUI, there isn't any problem.
After much experimenting, I figured out that if I changed the field names to something like 'count_20x', I am able to load the config.
So it would seem that there is a difference between the CLI and the GUI in that the CLI doesn't accept field names starting with a number...
-Al - kckirwan_49724
Al,
Thanks for the information. I just altered the fields in the profile and it worked like a champ!!!!!!
Kevin - Thanks for the feedback everyone!
I'll go ahead and update the tech tip.
-Joe
