Daniel_55334
Altostratus
Nov 15, 2011curl output not found in tcpdump
I tried to use curl to test a monitoring script and found the desired pattern to match. However the monitor still marks the pool member as down. I then used tcpdump to check the actual packet but I did not find that pattern.
Am I missing something?
- nitass
Employee
what the tcpdump command did you use? was the vlan name correct? - Daniel_55334
Altostratus
I used "tcpdump -i external -X -s0 host xxx and port 80". vlan name is correct as I really see related output, but just not the desired pattern.What I see is that there are a lot of output when using curl, but just very little during tcpdump capture when the monitor was turned on.
- nitass
Employee
pool member is in external vlan, isn't it?
have you tried to capture packet to file instead of screen and have a look it using tool such as wireshark?
e.g.
tcpdump -i external:nnn -s0 -w /var/tmp/output_file.pcap host x.x.x.x and port 80 - Daniel_55334
Altostratus
Yes I did check the capture in wireshark but still did not find the expected text pattern. What may be the cause of this? - nitass
Employee
how did you create monitor script file? did you upload it from pc to f5?
if yes, would you mind trying copy-and-paste instead? i have come across an issue about selinux similar to sol below.
sol11455: Moving a file across the BIG-IP file system may cause SELinux to deny access to the file
http://support.f5.com/kb/en-us/solutions/public/11000/400/sol11455 - Daniel_55334
Altostratus
no I just input it in the WEBUI - nitass
Employee
no I just input it in the WEBUIisn't it external monitor script?
may i have a look your configuration? just wondering if i can try in my unit. - Hamish
Cirrocumulus
Ah...
Is the poolmember expecting extra headers perhaps? The default HTTP monitors don't include the extra headers. And are probably HTTP/0.9 as well, which a lot of servers just don't like.
Make sure your monitor includes all the headers that your curl uses... (curl -v will show them to you).
H
