Joern_Oltmann's avatar
Joern_Oltmann
Jan 07, 2020
Crontab entry LTM Version 15.x not running
Hi @all,
I updated out LTM BIG-IP VE from Ver. 13.x to 15.x.
But now my cron entry for backup the Certs and ucs files are not running anymore.
In Ver. 13 I had a file located under /etc/cron.d/f5backup with the following content:
SHELL=/bin/bash
PATH=/sbin:/bin:/usr/sbin:/usr/bin
[email protected]
HOME=/var/tmp
2 0 * * * root /bin/bash /root/create_backup_bigip_v11.sh 1>/var/tmp/create_backup.log 2>&1
But on Ver. 15.x the cronjob is not running
Also an entry with crontab -e is not working
2 0 * * * /root/create_backup_bigip_v11.sh
Someone an idea?
  • Does the crond service run? Try: systemctl status crond
    What does logging show? Try: journalctl -u crond.service
    • Joern_Oltmann's avatar
      Joern_Oltmann
      Hi Nils, ups you are right the cron was not running ☹ But where should I put my cronjob? In the /etc/cron.d directory like in Ver. 13.x or directly in the crontab? Another question, how setup the cron daemon to run at startup? Thanks for the hint about cron running or not ☺ Joern Von: DevCentral Community Antworten an: Reply to DevCentral <0-1uqb5lh5rbnjoh.1rs1y8b7vmj96b5p.v837wuo38g2obvbt@m59xqeapnfh7v5nz.sylntfjh1l1263lb.0-hxqveae.na84.chatter.salesforce.com> Datum: Dienstag, 7. Januar 2020 um 11:52 An: "Oltmann, Jörn" Betreff: Niels van Sluis answered you: Crontab entry LTM Version 15.x not running Does the crond service run? Try: systemctl status crond What does logging show? Try: journalctl -u crond.service [https://devcentral.f5.com/ncsphoto/hmpm0h2mcimBkWKO762KIOOFQtgZMJk1MUi6nOmUOybQy58Gu1TG2fefJ-o6JSgX?fromEmail=1]<> Niels van Sluis<> Does the crond service run? Try: systemctl status crond What does logging show? Try: journalctl -u crond.service [cid:[email protected]] or reply to this email Replying to [https://devcentral.f5.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<> Joern Oltmann<> asked a question. Tuesday, January 7, 2020 2:38 AM<> Crontab entry LTM Version 15.x not running Hi @all, I updated out LTM BIG-IP VE from Ver. 13.x to 15.x. But now my cron entry for backup the Certs and ucs files are not running anymore. In Ver. 13 I had a file located under /etc/cron.d/f5backup with the following content: SHELL=/bin/bash PATH=/sbin:/bin:/usr/sbin:/usr/bin [email protected] HOME=/var/tmp 2 0 * * * root /bin/bash /root/create_backup_bigip_v11.sh 1>/var/tmp/create_backup.log 2>&1 But on Ver. 15.x the cronjob is not running Also an entry with crontab -e is not working 2 0 * * * /root/create_backup_bigip_v11.sh Someone an idea? [https://devcentral.f5.com/ncsphoto/hmpm0h2mcimBkWKO762KIOOFQtgZMJk1MUi6nOmUOybQy58Gu1TG2fefJ-o6JSgX?fromEmail=1]<> Niels van Sluis<> Does the crond service run? Try: systemctl status crond What does logging show? Try: journalctl -u crond.service Tuesday, January 7, 2020 2:52 AM<> You're receiving emails when someone "Comments on my posts." To change or turn off DevCentral email, log in<> as [email protected]. Are notifications about this post getting annoying? Reply to this email with the word " mute ". devcentral.f5.com | Seattle, WA Corporate HQ 401 Elliott Avenue West Seattle, WA 98119 [DevCentral]
      • Niels_van_Sluis's avatar
        Niels_van_Sluis
        Icon for MVP rankMVP
        Hi Joern,
        The crond should be started automaticaly. You can verify if it is enabled with the command 'systemctl status crond.service'. For example see the image below, and notice the 2nd line. The crond.service is enabled, and the vendor preset is enabled.
        It seems that you can use the /etc/cron.d directory or the root crontab directly.
