Vitor_Hugo_Domi
7 years agoCreate pool and vs in tmsh script
Hi guys,
I need your help! How to can I get the script for create pool and vs in tmsh?
Tks
- nathe
Cirrocumulus
Vitor,
A couple of places can help you, firstly Codeshare which is a DC repository full of useful scripts. A quick search on there shows scripts for VS/Pool creation.
Or if you want to build the scripts yourself then may I recommend TMSH Reference Guide
Hope these resources help. If you need help to validate your scripts then the DC community will certainly help.
Hope this helps,
N
