Daniel_55334's avatar
Daniel_55334
Apr 15, 2008
CPU utilization in v4 and v9
We measured CPU utilization in v4 and v9 under the same circumstances. We found that in v4 CPU utilization is nearly 0% (using "cpu bigip" command), while in v9 it is around 4% (using SNMP). Is there any method that can correlate the CPU utilization figures under v4 and v9?
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    Since the v4 and v9 systems are not only completely different from the ground up regarding software, but also hardware, it's not really possible to create a direct correlation between "x% CPU on v4 = y% CPU on v9".
    Is there a scoping question you'd like some guidance on?
    Colin
