MvdG's avatar
MvdG
Icon for Cirrus rankCirrus
Nov 08, 2017
CPU load while no traffic is passing BIGIP
Hi all,
Take a look at the graph below. This is the 7 day overview of the CPU load on a i4600 cluster BIGIP with LTM, APM, ASM and AFM provisioned. But for now only LTM is configured with about ten virtual servers. Nothing special, just LTM on internal webservers with a simple health check, client ssl profile and round robin load balancing. We see the same on the Standby BIGIP.
Now the strange part. This cluster isn't production yet, so no large amount of traffic is passing the BIGIP. Just one test user testing the applications which do not use large amount of active connections.
Can anyone explain why the CPU increases every day for some time and then drop again to lower levels? Is there a system process that runs every day? Is it the update check for the ASM signature database? And why do CPU 2 and CPU 6 not show the same? These CPU's remain low.
Regards, Martijn
  • It's hard to explain without analysing the system. I have seen this when ASM running the back-end Analytics or datasync.
    Also it looks like your odd number CPU is going up because it is used by Control plane rather data. there should be a datasync process that runs each day which will run up the CPU and does use Java. It should not impact traffic, however.
    https://support.f5.com/csp/article/K16469
    https://support.f5.com/csp/article/K15003
    Hope this helps.
    -Jinshu
