CPU HIGH IN LTM VIPRION
Hi
I need to understand that these logs are generating a balancer, which is a Guest who is in a team VIPRION product Vcmp found in version 11.3 both the chassis and the Guest, the platform is in a scheme of HA between Guest and stanlond between chassis.
Aug 1 08:09:10 slot2/f5-int1-1-dc1 err csyncd[5735]: 013b0004:3: Command failed: cmd=rsync -qaI --timeout=15 rsync://127.3.0.1/csync/shared/rrd.1.2/acl /shared/rrd.1.2/acl, rc=13 Aug 1 08:09:11 slot2/f5-int1-1-dc1 err csyncd[5735]: 013b0004:3: Command failed: cmd=rsync -qaI --timeout=15 rsync://127.3.0.1/csync/shared/rrd.1.2/ramcache /shared/rrd.1.2/ramcache, rc=13 Aug 1 08:09:12 slot2/f5-int1-1-dc1 err csyncd[5735]: 013b0004:3: Command failed: cmd=rsync -qaI --timeout=15 rsync://127.3.0.1/csync/shared/rrd.1.2/blade2cpu /shared/rrd.1.2/blade2cpu, rc=13 A
These logs are generated repetitively and the cpu view from the dashboard appears in 93%
- Arnaud_Lemaire
Employee
seems to be a synchronization issue for Ramcache between blades for you guest (assuming you have a guest on multiple baldes ?). can you try to remove webaccelleration profiles from your VS ?
