banjoooooooooo_
Oct 07, 2008Cpu and TMM monitor script
Hmm... I've been trying today to get the same results as the graphs in the TMUI for CPU and TMM usage I'm not sure why I'm getting different results and I noticed the results with my scripts below is bigger than whats in the TMUI stats... anyone could have a third look? Here's my script
!/usr/bin/perl
Usage: tmm-and-cpu.pl
use Net::SNMP qw(:snmp);
my $host = $ARGV[0];
my $snmp_comm = $ARGV[1];
chomp $host;
chomp $snmp_comm;
CPU Usage Definitions
my $cpuSysHostCpuUser = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.3.1';
my $cpuSysHostCpuNice = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.4.1';
my $cpuSysHostCpuIdle = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.5.1';
my $cpuSysHostCpuSyst = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.6.1';
my $cpuSysHostCpuIrq = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.7.1';
my $cpuSysHostCpuSoftIrq = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.8.1';
my $cpuSysHostCpuIoWait = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.9.1';
TMM Usage Definitions
my $tmmTotalCyl = '.1.3.6.1.4.1.3375.2.1.1.2.1.41.0';
my $tmmIdleCyl = '.1.3.6.1.4.1.3375.2.1.1.2.1.42.0';
my $tmmSleepCyl = '.1.3.6.1.4.1.3375.2.1.1.2.1.43.0';
my ($session, $error) = Net::SNMP->session(
-hostname => $host,
-community => $snmp_comm,
-port => 161,
-version => 'snmpv2c',
-nonblocking => 0
if (!defined $session)
print "Received no SNMP response from $host\n";
print STDERR "Error: $error\n";
exit -1;
poll CPU oids for Delta Calculations
my $cpu_oids_0 = $session->get_request(
-varbindlist =>
[$cpuSysHostCpuUser, $cpuSysHostCpuNice, $cpuSysHostCpuIdle, $cpuSysHostCpuSyst, $cpuSysHostCpuIrq, $cpuSysHostCpuSoftIrq, $cpuSysHostCpuIoWait] );
sleep 10;
my $cpu_oids_1 = $session->get_request(
-varbindlist =>
poll TMM oids for Delta Calculations
my $tmm_oids_0 = $session->get_request(
-varbindlist =>
[$tmmTotalCyl, $tmmIdleCyl, $tmmSleepCyl] );
sleep 10;
my $tmm_oids_1 = $session->get_request(
-varbindlist =>
CPU Deltas
my $DeltaCpuUser = $cpu_oids_0->{$cpuSysHostCpuUser} - $cpu_oids_1->{$cpuSysHostCpuUser};
my $DeltaCpuNice = $cpu_oids_0->{$cpuSysHostCpuNice} - $cpu_oids_1->{$cpuSysHostCpuNice};
my $DeltaCpuIdle = $cpu_oids_0->{$cpuSysHostCpuIdle} - $cpu_oids_1->{$cpuSysHostCpuIdle};
my $DeltaCpuSyst = $cpu_oids_0->{$cpuSysHostCpuSyst} - $cpu_oids_1->{$cpuSysHostCpuSyst};
my $DeltaCpuIrq = $cpu_oids_0->{$cpuSysHostCpuIrq} - $cpu_oids_1->{$cpuSysHostCpuIrq};
my $DeltaSoftIrq = $cpu_oids_0->{$cpuSysHostCpuSoftIrq} - $cpu_oids_1->{$cpuSysHostCpuSoftIrq};
my $DeltaCpuIoWait = $cpu_oids_0->{$cpuSysHostCpuIoWait} - $cpu_oids_1->{$cpuSysHostCpuIoWait};
TMM Deltas
my $DeltaTotalCyl = $tmm_oids_0->{$tmmTotalCyl} - $tmm_oids_1->{$tmmTotalCyl};
my $DeltaIdleCyl = $tmm_oids_0->{$tmmIdleCyl} - $tmm_oids_1->{$tmmIdleCyl};
my $DeltaSleepCyl = $tmm_oids_0->{$tmmSleepCyl} - $tmm_oids_1->{$tmmSleepCyl};
my $CpuUsage = ( ( $DeltaCpuUser + $DeltaCpuNice + $DeltaCpuSystem ) / ( $DeltaCpuUser + $DeltaCpuNice + $DeltaCpuIdle + $DeltaCpuSyst + $DeltaCpuIrq + $DeltaSoftIrq + $DeltaCpuIoWait ) * 100 );
my $TmmCpuUsage = ((($DeltaTotalCyl - ( $DeltaIdleCyl + $DeltaSleepCyl )) / $DeltaTotalCyl ) * 100 );
$CpuUsage = int($CpuUsage + .5);
$TmmCpuUsage = int($TmmCpuUsage + .5);
print $CpuUsage;
print "\n".$TmmCpuUsage;
This calculations are based on the latest NSM for BIG-IP.
Thanks!!!
- Kevin_51676
I pipe the output of the script into Cacti for graphing purposes.
Here is what I use for the host cpu script:
$ more f5-bigip-host-cpu.pl
!/usr/bin/perl
Host CPU Monitor Script
This works for 2 Processor Boxes, running 9.3.x
There is a new method for 2 Processor Boxes, running 9.4.x
Usage: f5-bigip-host-cpu.pl
chomp $host;
chomp $snmp_comm;
my $User = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.3.1';
my $Nice = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.4.1';
my $System = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.5.1';
my $IdleCyl = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.6.1';
my $IrqCyl = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.7.1';
my $SoftIrq = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.8.1';
my $IoWait = '.1.3.6.1.4.1.3375.2.1.7.2.2.1.9.1';
-hostname => $host,
-port => 161,
-nonblocking => 0
exit -1;
poll CPU oids
my $polled_oids_0 = $session->get_request(
-varbindlist =>
[$User, $Nice, $System, $IdleCyl, $IrqCyl, $SoftIrq, $IoWait]
sleep 10;
my $polled_oids_1 = $session->get_request(
-varbindlist =>
Calculate Delta
$Nice = ($polled_oids_1->{$Nice} - $polled_oids_0->{$Nice});
$System = ($polled_oids_1->{$System} - $polled_oids_0->{$System});
$User = ($polled_oids_1->{$User} - $polled_oids_0->{$User});
$IdleCyl = ($polled_oids_1->{$IdleCyl} - $polled_oids_0->{$IdleCyl});
$IrqCyl = ($polled_oids_1->{$IrqCyl} - $polled_oids_0->{$IrqCyl});
$SoftIrq = ($polled_oids_1->{$SoftIrq} - $polled_oids_0->{$SoftIrq});
$IoWait = ($polled_oids_1->{$IoWait} - $polled_oids_0->{$IoWait});
calculate CPU Utilization
my $cpu = ((($Nice + $User + $System) / ($Nice + $User + $System + $IdleCyl + $I
rqCyl + $SoftIrq + $IoWait)) * 100);
Round to integer
$cpu = int;
print CPU Utilization to stdout for cli validation
print $cpu; - Kevin_51676
Here is what I use for the TMM CPU:
$ more f5-bigip-tmm-cpu.pl
!/usr/bin/perl
Usage: f5-bigip-tmm-cpu.pl
chomp $host;
chomp $snmp_comm;
-hostname => $host,
-port => 161,
-nonblocking => 0
exit -1;
poll CPU oids
-varbindlist =>
sleep 10;
-varbindlist =>
my $tmm_cpu = (( ($polled_oids_1->{$tmmTotalCyl} - $polled_oids_0->{$tmmTotalCyl
( ($polled_oids_1->{$tmmIdleCyl} - $polled_oids_0->{$tmmIdleCyl}
($polled_oids_1->{$tmmSleepCyl} - $polled_oids_0->{$tmmSleepCyl}
/ ($polled_oids_1->{$tmmTotalCyl} - $polled_oids_0->{$tmmTotalCy
l}) ) * 100 ;
Round to integer
$tmm_cpu = int($tmm_cpu + .5);
print $tmm_cpu; - Kevin_51676
For 9.4.x if you want to get the CPU % Utilized all you need for the host is this SNMP OID: .1.3.6.1.4.1.3375.2.1.7.5.2.1.11.1.49.1 - Zafer_101134
Hi
i had problem with these lines in script
my $host = $ARGVΎ]
my $snmp_comm = $ARGVΏ]
is that correct
and i saw oid for cpu usage, when i look the ask.f5.com i see alot of parameters and calculation and these last message gives me cpu usage
snmpwalk -c public -v 2c 192.168.0.120 .1.3.6.1.4.1.3375.2.1.7.5.2.1.11.1.49.1
SNMPv2-SMI::enterprises.3375.2.1.7.5.2.1.11.1.49.1 = Counter64: 5
so is that possible to give me oid numbers for version 9.4.5
i had oid numbers from support guys and tech.f5.com but it does not give what i wants
i want see Cpu usage (host and tmm)
memory usage and interfaces usage
regards
Zafer - hwidjaja_37598
Altostratus
try this:my ($host, $snmp_comm) = @ARGV; - zafer
it worked
thanks
zafer - steve_111974
hi, i'm running 9.3.1. i copied your script for cpu utilization (f5-bigip-tmm-cpu.pl).
these are the message I'm getting. any suggestions?
12/11/2008 05:25:22 PM - SPINE: Poller[0] Host[103] ERROR: Empty result [10.4.224.28]: 'perl /usr/share/cacti/site/scripts/f5-bigip-tmm-cpu.pl 10.4.224.28 d1n&0l1n&'
12/11/2008 05:25:22 PM - SPINE: Poller[0] Host[103] DS[1813] WARNING: Result from SCRIPT not valid. Partial Result: ...
12/11/2008 05:25:22 PM - SPINE: Poller[0] Host[103] DS[1250] WARNING: Result from SCRIPT not valid. Partial Result: ...
