draco
Dec 28, 2017Couple of questions regarding ASM.
1) if i choose enforcement readiness to 7 days, then after 7 days will the enforcement mode change from transparent to blocking automatically ? or does it just mean the system starts suggesting the entities and attack signatures are to be enforced or not ?
2)For SSO authentication , is there any protection that can be given from ASM ?
3)Has any deployed ASM for open text based CMS ?
4) For NTLM authentication used on application, what are the protection that can be done on ASM ?
Do Reply and thanks!
