draco_184361's avatar
draco_184361
Dec 28, 2017
Couple of questions regarding ASM.
1) if i choose enforcement readiness to 7 days, then after 7 days will the enforcement mode change from transparent to blocking automatically ? or does it just mean the system starts suggesting the entities and attack signatures are to be enforced or not ?
2)For SSO authentication , is there any protection that can be given from ASM ?
3)Has any deployed ASM for open text based CMS ?
4) For NTLM authentication used on application, what are the protection that can be done on ASM ?
Do Reply and thanks!
  • 1) if i choose enforcement readiness to 7 days, then after 7 days will the enforcement mode change from transparent to blocking automatically ? or does it just mean the system starts suggesting the entities and attack signatures are to be enforced or not ?
    it wont block until you update policy as block mode, the period just suggest entities and attack signatures.
    2)For SSO authentication , is there any protection that can be given from ASM ? i dont think any specific thing on ASM,mostly it should be via APM
    3)Has any deployed ASM for open text based CMS ? not sure
    4) For NTLM authentication used on application, what are the protection that can be done on ASM ? normally, start with default ASM signatures and based on event logs keep update all you files,parameters,ips etc to blcok...
