Cookies based persistance issue
Hi
I'm trying to enable cookies based persistence on my virtual server. I follow all the steps required to enable cookies persistence. I have 3 IIS server hosting public portal https://XYZ.com. Steps i follow 1. Enable http profile on virtual server 2. Enable cookies persistence on Resources Tab.
My issue right now is I'm not able to access Portal https://XYZ.com enabled cookies persistence. If I remove http profile and cookies persistence then im able to access the portal. Anything did i missed here?
- Shamsul_Alam_34
Did I missed anything here?
- nathe
Cirrocumulus
Do you have a client SSL profile? I note it's a HTTPS virtual server. You will need to decrypt the traffic for layer 7 objects such as cookies to work.
Hope this helps,
N
