James_78615
Apr 21, 2009Cookie persistence for certain host headers
I have the requirement to enable cookie persistence when a user hits a particular subdomain for a site.
For example, insert a cookie and use cookie persistence for abc.site.com but any other requests for *.site.com should be load balanced without persistence.
Is this possible using the following rules?
profile persist abc_passive_cookie
defaults from cookie
mode cookie
cookie mode passive
cookie name "abc_passive_cookie"
virtual WebVS
pool WebPool
destination 1.1.1.1:http
ip protocol tcp
rules abc_persist_cookie_insert
profiles
http
tcp
rule abc_persist_cookie_insert
if { ([string tolower [HTTP::host]] starts_with "abc.") } {
persist cookie insert abc_persist_cookie
James
- The_Bhattman
Hi James,
Since you are associating a profile persistence cookie to the vip resource then you could get a way with simply doing the following:when HTTP_REQUEST { if { not ([string tolower [HTTP::host]] equals "abc.site.com") } { persist none } }
hope this helps
CB - James_78615
Thanks CB, that works great.
Is it possible to use an irule to insert a persist cookie without assigning a persistence profile to the vip? When I tried to do this I got an error when creating the irule.
James - hoolio
No, you must have a cookie insert persistence profile added to the VIP in order to use 'persist cookie insert'.
Aaron
