Connection Timout Problem in Load balancing
- Oct 22, 2014
You could try specifying a Maximum Requests value of "1" in an HTTP profile and apply it to the virtual server.
Chances are that the client is re-using the same TCP connection for multiple HTTP requests. The profile change would limit the client to one HTTP request per connection. You could also enable oneconnect on the VS and see if that makes a difference
- Muhammad_Irfan1Oct 23, 2014
Cirrus
Great Sir, that solved my problem. I have one small another question, I have a client side SSL profile enabled and successful handshakes are happening. But the problem is that when same user generates another request each time he has to pass through SSL handshake, I think his second request should be faster. How can I achieve that. Thanks
