Connection Timout Problem in Load balancing
- Oct 22, 2014
You could try specifying a Maximum Requests value of "1" in an HTTP profile and apply it to the virtual server.
Chances are that the client is re-using the same TCP connection for multiple HTTP requests. The profile change would limit the client to one HTTP request per connection. You could also enable oneconnect on the VS and see if that makes a difference
I understand you want to create a persistence. With persistence profile, you can create stickiness to pool member. This stickiness can be controlled with time out setting. The link below may help to create persistence profile, https://support.f5.com/kb/en-us/solutions/public/7000/000/sol7019.html
