Connection TCP 1433 doesn't work across a Virtual Server Transparent of a Viprion
I have a socket to do of a TCP 1433 connection from the server side to the client side of a Viprion to send a great deal of DATA. The Viprion has a a Guest which manages this traffic with a Virtual Server Transparent. The connection is done but when it starts to send the DATA, at a certain point, it doesn't work.
I've modified the timeouts of the profile fastl4 and the TCP window size with no results.
Does anybody know anything about it? It's very urgent, please.
Thanks a lot.
Carlos
- What_Lies_Bene1
Doesn't work? Any error messages or similar?
SQL traffic? Exactly how much data?
Is the server Linux?
There's lots we can do here, especially if you can create a VS just for this port, but need a bit more info please.
- 0_169654
Sorry, we've just found the solution.
We've checked the "loose initiation" and the "loose close" and it has worked.
We think that application loses certain packets which makes Viprion to tear down the connection, because it thinks that is an asimetric traffic.
I don't know if I've explained myself well.
Thanks for helping so quick.
Best Regards.
Carlos
