yugraj_rai_1230
Sep 17, 2014connection reset after 60 to 100 seconds of being idle
We came to a conclusion that BigIP is causing connection reset when we stream media through it (https traffic). We are not seeing the same issue when access the media directly off the server
- Angelo
you should be able to set a idle time on yout http profile...
- yugraj_rai_1230
how to idle time on http profile
- yugraj_rai_1230
how to set idle time on http profile
- Angelo
Hi
Sorry my mistake in the persistence profile there is a timeout section
ltm persistence source-addr source_addr { app-service none map-proxies enabled mask none mirror disabled timeout 180 }
