iloveniu_38329
Mar 05, 2010connection problem... ...
i have several problem about connection information about the BIGIP.
1,what is the best way to get the number of connections of the nodes?
2,now,how can i clear the connections which started by the specified client ip address?
thanks for your reply!
- Cspillane_18296
Hello iloveniu,
use the CLI command 'bigtop' to see the number of connections to the nodes.
If you are running version the the Dashboard can show you the total number of connections /new connections to the BigIP.
Also Overview>Traffic Summary>General in the GUI will show you the number of active clientside and server side connections. You can also clear the statistics here.
I don't believe there is a way to clear the statistics for an individual client IP.
