Wes_98712
Mar 31, 2006Connection Pooling
I am looking for some solid examples as to how to enable connection pooling on v9. What I would like to know is as follows:
1. Can we setup a connection pool and put a default number of connections (e.g. similar to something like weblogic that can open 50 connections and cycle through them)?
2. If not, then I suppose the purpose of oneconnect is to reuse connections as they are created?
Any solid irule examples, or examples period would be greatly appreciated.
-Wes
- Colin_Walker_12Historic F5 AccountYou wouldn't need an iRule at all to make use of connection pooling. This is what the OneConnect feature is designed for. Any questions about the feature that you might have would probably be best directed to product support.
-Colin
