dogg_dogg_23774
Jun 06, 2013connection limit by subnet
I have a group of users in 10.1.1.0/24 segment, and anothe group in 10.3.1.0/24. What I want to do is if concurrent connection from 10.1.1.0/24 is greater than 100, drop connection request from 10.3.1.0/24, otherwise accept connection from 10.3.1.0/24 as well. No limit on 10.1.1.0/24 side.
I am having trouble figuring out how to do this. Does anyone have samples that make it possible?
Thanks,
- nitass
Employee
i think you may add 10.1.1.0/24 client to table when connection is established and remove it when it is closed. when 10.3.1.0/24 client comes, count table to see whether it reaches threshold. if yes, drop 10.3.1.0/24 client. static::lifetime is set in case CLIENT_CLOSED is not triggered, so entry won't be in table forever.
e.g.[root@ve10:Active] config b rule myrule list rule myrule { when RULE_INIT { set static::lifetime 86400 set static::limit 100 } when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals 10.1.1.0/24] } { table set -subtable "connlimit" "[IP::client_addr]:[TCP::client_port]" " " indefinite $static::lifetime return } if { [table keys -subtable "connlimit" -count] > $static::limit } { if { [IP::addr [IP::client_addr] equals 10.3.1.0/24] } { drop } } } when CLIENT_CLOSED { if { [IP::addr [IP::client_addr] equals 10.1.1.0/24] } { table delete -subtable "connlimit" "[IP::client_addr]:[TCP::client_port]" } } }
