Connecting to LTM using VMware Orchestrator F5 plugin
Working with VMware Orchestrator 5.5: Attempting a connection using "Attach LTM" plugin fails when "Use REST API flag" is set to 'no'. The plugin finishes successfully; however, the status shows "unconnected".
Attempting a connection using "Attach LTM" plugin succeeds when "Use REST API flag" is set to 'yes'. Also, connections to LTM using the Orchestrator REST plugins work properly. These connections pass through a firewall. LTM version 11.5.1 in use.
What changes for the attempted connection when not using the REST API flag ? Is there any setting on the LTM load balancer that can be modified to achieve success?
- Paul_Pindell_73Historic F5 Account
Make sure that you have updated the REST framework on the BIG-IP to which you are connecting first.
http://support.f5.com/kb/en-us/products/big-iq-security/manuals/product/bigiq-security-administration-4-2-0/11.html
This guide will tell you how to update the REST framework
Paul
- Jose_Luis_Gomez
Hi, I have the same issue. Can I update the REST framework if I don't have BIG-IQ? Regards, Jose
- Paul_Pindell
Employee
Paul
- Jose_Luis_Gomez
- slaser_159976
thank you!
