Configuring SSO for Siebel Call Center 7.8
What are APM SSO configuration parameters for Siebel Call Center?
- Chris_Akker_129Historic F5 Account
Hi Greg, the answer to this depends on how you have user authentication/SSO set up on Siebel itself. If you are using Oracle Access Manager, we have 2 solutions with APM.
User Auth only, using the OAM/OID LDAP server: http://www.f5.com/pdf/deployment-guides/big-ip-apm-dg.pdf
User Auth and Web Access Control, replacing the Webgate agent on the OHS servers. There are two solutions, one for OAM 10g, and one for OAM 11g:
https://f5.com/solutions/deployment-guides/oracle-access-manager-big-ip-apm-v1021
https://f5.com/solutions/deployment-guides/oracle-access-manager-big-ip-v11-apm
If you are using something different, let us know.
Good Luck! -Chris
