Configuring HA on VIPRION 2400 with two blades
we are having a viprion chassis with two blades(2150). please suggest me in setting up a HA pair between two blades. some of my questions are before setting up a HA pair
- Is it necessary to configure to two different VLAN groups on two blades from HA?
- Is it necessary that we configure two mgmt IP's to two cluster members for configuring HA ?
- Is it possible to handle two blades using one management IP?
Thanks,
Sekhar
- nitass_89166
Noctilucent
chassis operates as one device. configuration is applied to all the blades.
sol14392: Configuring a cluster member IP address for all slots on a VIPRION platform
https://support.f5.com/kb/en-us/solutions/public/14000/300/sol14392.htmlIs it possible to handle two blades using one management IP?
it is what cluster ip is used for.
- Sekhar
Hi Nitass, Thank you for replying back. My question is what is the advantage of having cluster IP and cluster member IP address? Is it possible to break cluster and configure two blades as two individual standalone devices? Thanks, Sekhar
- nitass
Employee
- Sekhar
- nitass
Employee
cluster member ip is like non-floating selfip. cluster ip is floating selfip (it is always on primary blade).
no
- Sekhar
HI Nitass, We are looking for a failover scenario between two blades on a single chassis. Is it ok if we connect just on HA vlan interface between two blades for successful failover between blades? Please suggest the best practice Thanks, Sekhae
- nitass_89166
Noctilucent
no
- Sekhar
- nitass
Employee
i understand blade mirroring does not use ha vlan. you may check document about cluster network mirroring.
- nitass
Employee
i cannot find 11.x document but 10.x. Configuring Mirroring for VIPRION Systems https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/viprion_configuration_guide_10_1/clustered_systems_mirroring.html
- nitass_89166
Noctilucent
- nitass_89166
Noctilucent
