Jesse_Wahl_3952's avatar
Jesse_Wahl_3952
Historic F5 Account
Apr 06, 2011
Configuring alerts to send email notifications with variable body content
After following sol3667: Configuring alerts to send email notifications and sol7574: Monitoring SSL certificate expiration on the BIG-IP system
and configuring an alert similar to the following example alert:
alert MY_TEST_ALERT "will expire on" {
snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.28.666";
email toaddress="[email protected]"
fromaddress="root"
body="The test of this Solution worked!"
I was able to test and the emails show up fine.
This is great, however, I would like to include the original log message that triggered the trap, from /var/log/ltm, to be included in the body of the email.
Is there a variable that can be used in the "body=" section of the alert that will be replaced by the log message that triggered the trap?
or, could the text of the message body be read from a file?
Thanks in advance for your help!
-J
  • hoolio's avatar
    hoolio
    Hi Jesse,
    I am not sure what variables are possible in the alert.conf. Can you open a case with F5 Support on this and reply back with what you find out for future reference?
    Thanks, Aaron
  • Hi,
    Can I use a specific veriable in body message? Like Body="%pool %member is down"
    Thanks for your interest,
  • Can I use a specific veriable in body message? Like Body="%pool %member is down"
    i think it is not possible (as of now).
